heelclicker on a sportsman 500????
Old Dec 27, 2003 | 10:44 PM
polarisbear500's Avatar
Default heelclicker on a sportsman 500????
i have done searches on the forum on the heelclicker and everyone seems to love it. 2 questions: Can anyone that can follow directions install this kit without a professional? And, Where is the best place to get a deal on the kit. Thanks, PB500
Old Dec 27, 2003 | 11:16 PM
fishslab's Avatar
Anyone with a normal set of tools (torque wrench, sockets,etc..)should be able to install one. I hear HiLifter has good deals, but I don't know that for sure.
Old Dec 28, 2003 | 12:53 AM
BigBadScrambler's Avatar
I believe that the Spider needs to be removed and modified with the Heelclicker kit. That does require special tools.
Old Dec 28, 2003 | 01:19 AM
Sniff's Avatar
It’s fairly simple to install. I did the whole thing (including the full shift out clutch modification) in about 3 hours. The only tool I didn’t have on hand was the heavy duty snap ring pliers. You really don’t need to have any special tools. Not even for the secondary clutch but your hands will hurt for a while after you are done. My palm was sore for a few hours after holding everything together with one hand and installing the snap ring with the other. It took about 15 min to get the technique down. I did the whole job by myself and with only standard hand tools. Make sure you have a good metal file, a torque wrench and good set of snap ring pliers.
The Heelclicker site has an option at the top right called “24/7 Tech Support”. Click on that and you can see pictures of what will be required. It’s a step by step guide to getting it done and it did help me some. You don’t need to remove the spider on the 500.
Heelclicker 24/7 Tech Support - Look below the picture to see the other topics
The cheapest place to get the Heelclicker kit is from the ATV Quad Squad home page. I paid less than $160 bucks delivered if I remember correctly.
Old Dec 28, 2003 | 08:10 AM
500DUSE's Avatar
The best place to get a deal on it is right hear.
125 and its yours
I tried both the HC and the Dalton and decided to go with the Dalton
A clutch puller is the only special tool needed.
The 700's need a spyder tool but that has nothing to do with you
Old Dec 28, 2003 | 02:46 PM
See, I knew that the spyder needed to be removec on something[img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 28, 2003 | 06:38 PM
PolarisOkie's Avatar
500 DUSE, what is better about the Dalton over HeelClicker? Heard just a little about the Dalton. Also, was this on a 500 or 700? Thanks..Okie
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
