p360 engine noise
Old Dec 28, 2003 | 02:24 PM
p360nh's Avatar
Default p360 engine noise
top end engine noise ? valves have been adjusted and machine starts and runs great.
engine is quiet from cold start to about 15 minutes of normal use. after that it starts a top end ticking noise. not destruction iminent noise, but just annoying. it goes away at higher revs. it is worse after a hot shutdown, then a restart soon there after. ticking developed slowly over the course of six months. no engine mods, and machine was not beat or poorly maintained.
anyone had a 360 with these symptoms? I am thinking bad cam bearing,valve guides, cam itself? maybe i should just not worry about it. it is noticeable, but not worth a tear down yet.
thanks for the ideas.
Old Dec 29, 2003 | 12:57 AM
03P360's Avatar
Mine also makes that sound. My bayou 220 did as well so I just haven't worried about it. If it does end up being something bad in the long run then I'll just take the hit and fix it.
Old Dec 29, 2003 | 04:31 PM
p360nh's Avatar
thanks 03p360. i have the same winch as you and run the epi black spring. all my other power toys have been 2 strokes. the 03 p360 is my first 4 stroke. kinda bummed by that ticking noise, but i can live with it for now. it will probably run fine for the next 10 years always making that noise. just wanted to see if anyone else had the sound too.
Old Dec 29, 2003 | 05:12 PM
WileyCoyote's Avatar
Although it's a different engine, my KLR-650 dual sport makes a lot of worrisome noise, too. Especially after I ride it for a long time at high RPMs. After 35,000 miles and one major crash into a deer, I've come to realize Kawasaki makes a pretty good motor, even if it does make strange noise. I wouldn't worry too much about it.
Old Dec 30, 2003 | 01:31 AM
03P360's Avatar
I don't even really notice it anymore. It's there if I actually listen for it but I've ignored it so long that durring normal riding I don't even hear it. As for the winch, its a lifesaver when you need it but make sure you give it a few breaks when you are doing a heavy pull. Mine is making some grinding noise because I overloaded it and it got real hot while I was trying to pull a sportsman out of thick weedy mud. Otherwise Its great and so is the machine. Hope you have lots of fun with your like I have been.
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
