chains and stuff
Old Dec 28, 2003 | 10:17 PM
jamag's Avatar
Default chains and stuff
need some help guys, busted a roller out of the chain this weekend (all that ritter power)lol, this will be the second chain i have put on this bike, the first one was done under warranty, so i didnt really pay attention to the specifics of it, now this one gotta come out of my pocket, (520x84) what does the 84 stand for, and what is the correct size for my 02 trailblazer??? what brand chain would you all suggest?
2ndly, need to replace the tie rod ends already, should i just go back with o.e.m. ends or is there any company out there that makes an aftermarket (stronger) set for my bike? always have replaced worn out factory items with the best built in the past, are o.e's the best? whats out there?
thanks
james
Old Dec 28, 2003 | 11:34 PM
lslubecki's Avatar
520 is the chain size and 84 are the number of links. Any good o ring chain I think would be ok but maybe others have more experience whit chain quality and durability.
Steve Lubecki
Old Dec 28, 2003 | 11:57 PM
jamag's Avatar
what is the correct size then for my 02 t.b.?
james
Old Dec 29, 2003 | 12:10 AM
scrambler420's Avatar
where did you come up with 520/86?your machine takes a 520/76 pin i think.if you want the very best chain then go with sidewinder,dought it will ever brake again.its pretty expensive though..i was broke 3 chains(i think) on my scrambler400,i ended up going with a DID x-ring chain and its holding up pretty well
and it only cost like $45..also change your sprockets when you get a new chain other wise youll reuin the sprockets you have and probably the chain too..
Old Dec 29, 2003 | 04:07 AM
BigBadScrambler's Avatar
I too have a DID X-ring chain. The master link they gave me wouldnt fit. I had to use a 530 masterlink for soem reason. Havent had any trouble with it. I also got new Sunstar sprockets from Hot Seat. Check into EPI for tie rod ends
Old Dec 29, 2003 | 10:47 PM
Stickhauler's Avatar
I 3 have a DID Xring chain on my machine. I damn near had to press the outer plate onto my master link to get it on. Haven't had any problems with their chains in the past. I also am partial to Sunstar sprockets. They are the best for the money. IMO!!
Old Dec 30, 2003 | 12:13 AM
Good. And I thought I was the only one that had a hell of a time with the X-ring master link.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 3, 2004 | 02:01 PM
jamag's Avatar
okay, which brand is the best trade of cost, and strenght, i dont wnat any troubles getting the chain on when replaced... havent ever changed a chain what is the process? and do i need a chain breaker or chain press? and again does anyone know what size of chain do i need?
james
Old Jan 4, 2004 | 02:02 AM
jamag's Avatar
c'mon guys, any help here?
james
Old Jan 4, 2004 | 02:09 AM
#19 520x76 pitch o-ring chain. I like to order mine with at least 3 extra links just in case. You will want a chain breaker to cut it to the proper lenght. They are only like $10-15. The DID X-ring chain is a great chain. I havent had any trouble with it, except with the master link
