Barnett Clutch Plates
Old Dec 30, 2003 | 01:43 PM
ScoobyDFW's Avatar
Default Barnett Clutch Plates
Where can I buy a set of the 8 carbon fiber and 1 kevlar friction plates for the DS? I don't want to buy the whole clutch kit with steels and springs. Theres no part number for just the friction plates?
Last time I tried ordering plates by indiviual plate part number it took forever!!!
Old Dec 30, 2003 | 03:24 PM
PUSHINTHELIMIT's Avatar
Why do you want a barnett clutch? I thought they were really crappy?
Old Dec 30, 2003 | 07:34 PM
thebigshow's Avatar
mine fell apart after three trips. but i wasnt running the heavy duty springs either.
Old Dec 31, 2003 | 12:27 AM
JMAC650's Avatar
Stock clutch & Ron Woods 60% springs is the best way to go.
Old Dec 31, 2003 | 12:35 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Scooby is running more power than most.
I tryed the Barnett with the best Pami springs and they sliped after about 10 passes. I went back to the stock clutches with the Pami spring and no more problems.
Sorry this isn't much help.
J Ross
Old Dec 31, 2003 | 12:57 AM
DSWOLF's Avatar
i have the new woods springs and i put the sandpaper to my metal plates to rough them up and now it's great..
Old Dec 31, 2003 | 03:23 AM
SandMan12's Avatar
Scooby do you ever ride Pismo? I would like to see your bike run. How much hp are you putting down with that thing? Later
Old Dec 31, 2003 | 03:52 PM
ScoobyDFW's Avatar
i need the extra friction plate to increase the surface area.
with enough spring pressure, the barnett doesn't slip. you will lose a fiber or two though. if the barnett does slip, it goes fast and contaminates the oil.
i use (9) 1.5mm steel plates, re-surfaced. the 1.2mm steel plates will warp.
Old Dec 31, 2003 | 08:14 PM
ScoobyDFW's Avatar
Barnett says they don't have a part number for the friction plates as a set, you have to special order them by individual part number:
carbon fiber friction plate: K-1000CF
outer kevlar friction plate: K-1000B
Old Dec 31, 2003 | 08:19 PM
beachbum's Avatar
hey scooby i just go to there web site pick up there number and call them . thats how i got there cool looking fuel filter. good luck
