Has anyone seen the "DIAL A JET"?
Old Jan 2, 2004 | 01:28 PM
FUFIGHTER's Avatar
Default Has anyone seen the new "DIAL A JET"?
Hi all I've seen a new product out there called DIAL a JET it's from thunder products it looks good to me, just want a second opinion, check out WWW.THUNDERPRODUCTS.COM and click on DIAL a JET and tell me what you think!
Old Jan 2, 2004 | 01:59 PM
dragracer789's Avatar
Default Has anyone seen the new "DIAL A JET"? This is a must see!!!
They have been out for quiet a while now man.
Old Jan 2, 2004 | 02:05 PM
FUFIGHTER's Avatar
I know they've been out for sleds but not ATVS.
Old Jan 2, 2004 | 02:33 PM
SHOTGUN's Avatar
they are all the same, had mine for two years.
Old Jan 2, 2004 | 02:37 PM
eiger2's Avatar
That looks pretty interesting. I couldn't find a price tho. I know when you add a pipe you should rejet and this looks like it would take care of that. Since there are so many visitors to this site there must be someone who has tried it. If it works on a snowmobile it will work on a quad.
Old Jan 2, 2004 | 02:39 PM
eiger2's Avatar
Shotgun, are you saying that you have used them for years?? Do they work?
Old Jan 2, 2004 | 03:04 PM
SHOTGUN's Avatar
I have use them for two years, but I use mine differently than most.
I have a small 1 quart tank under my seat, that I mix gas and Nitro and spray the mixture into the tops of the carbs with the dial a jet, when I pull.
I know a lot of people use them, mostly so they don't have to rejet when changing elevations. You need to go down 2 jet sizes to give room for them to work.
Talk to Lorn, he is the owner of thunder products and a good guy to talk to, he'll answer your questions.
Old Jan 3, 2004 | 02:40 PM
FUFIGHTER's Avatar
Finally some concrete opinions, thanks guys i got alot of guys telling me they've been around awile but no one with opinions. Can always count on SHOT GUN!!!
Old Jan 5, 2004 | 12:29 AM
Chris142's Avatar
Default Has anyone seen the "DIAL A JET"?
My friend has a kfx and his sister inlaw has a z-400. Both bikes ran terrible above 4000 ft. Re-Jetting became a pita since we sometimes ride from 2000ft to 8000ft and back in a a day.
Both bikes got a dial-a-jet and the jetting problems are over. Both run much better at any elevation and get slightly better mpg.
Old Jan 6, 2004 | 03:16 PM
FUFIGHTER's Avatar
One thing I really like about them is they drain the floatbowl!
