v force belt deflection adjustment?
Old Jan 2, 2004 | 01:38 PM
jroffroad's Avatar
Default v force belt deflection adjustment?
my belt has about 1 1/4 deflection. i have put a new primary spring in. so i can get that far. i need to know what shim to get, where to put it, and where to get it. will the dealer have it in stock, if it is the same as the prarie they should have plenty, right?
Old Jan 3, 2004 | 07:35 PM
jroffroad's Avatar
don't answer all at once
Old Jan 3, 2004 | 08:25 PM
Vforcer's Avatar
The shim is inside the the rear pully unit. You will need to remove the pully, compress the spring, remove the snap ring,
shake the little guide pins out of the middle (without losing them!), slide the pullies apart, REMOVE a shim to tighten belt.
As for the Dealer stocking it .... good luck! My dealer doesn't stock anything like that. They don't even stock the belt!!
The answer the phone saying "parts deptment." but they ain't fooling me... they should be saying "order department".
( Norris in Medina Ohio )
Old Jan 4, 2004 | 09:34 AM
jroffroad's Avatar
doesn't sound bad, thanks. i found a site that shows the secondary apart, looks simple
Old Jan 4, 2004 | 02:38 PM
Vforcer's Avatar
Pretty simple really ... It will be much easier if you have something to compress the
spring with.
Old Jan 4, 2004 | 03:02 PM
SandSam's Avatar
Hey VForcer...how do you like your Web Cams? What kind of difference did they make in power?
Did you have to make any adjustments ( fuel, air, etc...) ?
Old Jan 4, 2004 | 06:39 PM
Vforcer's Avatar
My guess: The cams and with jet changes made about a five horse power difference
About the same as the duals and jet/air box changes did ....
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
