2000 Honda Rancher ES
Old Jan 2, 2004 | 01:54 PM
Gene501's Avatar
Default 2000 Honda Rancher ES
I have a 2000 Honda Rancher ES and the transmission is stuck in 5th gear. I have tried to shift gears with the electric shifter and the manual shifter with no luck. I have rocked the Rancher back and forth and it will still not shift. Help!
Old Jan 2, 2004 | 06:35 PM
roscoe69's Avatar
gene 501
some of the early honda rancher 350 es had shifting fork problems, i dont knew what years were envolved but i do knew it was before 2001 because i held off buying one untill the 2001 were out. i believe there was a recall or something, there was also a front end part recall something about a arm welds or parts in that area. get your serial # and call your local honda dealer about it. it may have or should have been part of honda recall.
Old Jan 2, 2004 | 10:01 PM
Gene501's Avatar
roscoe 69
Thanks for the info. I worked on the machine for several hours and took it to my local ATV repairman. I borrowed my brother-in-law's Honda Fourtrax and went to Vienna(1200 acres of God's Country) with the Navidad River running through it.
Thanks again.
Gene501
Old Jan 2, 2004 | 10:19 PM
dzzy's Avatar
As roscoe69 points out, you may want to check with your local Honda franchised dealer, it seems to me they are covering those repairs yet. Or if you can find those service bulletins on the web somewhere, you can check the ending date yourself.
Old Jan 2, 2004 | 10:24 PM
Gene501's Avatar
dzzy,
Thanks for the input. I will try to find a service bulletin.
Gene501
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
