Hando 400EX carb on Lakota Sport
Old Jan 2, 2004 | 07:18 PM
sandmudandhills's Avatar
Default Hando 400EX carb on Lakota Sport
I read a post on another board about how well the Stock Honda 400ex carb worked on a Mojave and im starting to think if it works well on the 250 it should work just as well or better on my 300. Has anyone tried this? I can get the carb new for under $100 so unless theres a real good reason not to I plan to try it soon.
For those who dont know the stock carb (i believe) is 1.5mm larger than a stock mojave carb and has an accelerator pump. I imagine that makes the carb 35.5mm but im not sure.
Old Jan 2, 2004 | 07:19 PM
I just realized I read it on this board the post is just under this one [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 2, 2004 | 09:54 PM
Any insight?
Old Jan 5, 2004 | 12:38 AM
mdyjeepgrl's Avatar
i've heard of placing a mojave carb on a lakota but i'm not sure about the 400ex carb. I actually purchased the mojave carb on ebay, but haven't gotten around to it. I read, also on the forum, that the swap will give the lakota more of a boost.
Old Jan 5, 2004 | 12:39 AM
mdyjeepgrl's Avatar
One more thing, what excess weight did you remove and how much lighter is it. I need to take some weight off mine.
Old Jan 5, 2004 | 10:49 AM
stebob's Avatar
I think the 400EX carb would be too big unless you have significant engine mods. However, the 300EX carb. may be the way to go. You will no longer have a bar mounted choke lever, but I think it would work ok. I believe it has an accel. pump, like the 400EX's. Jetting? Beats me.
Good luck and let us know what you come up with!
Old Aug 6, 2004 | 11:43 PM
kwackermann's Avatar
.... That's right, the 400ex carb would be too large, however this is a popular Mojave mod because it is only 1.5mm larger than the 'jave 's 34mmunit and it has an accelerator pump. An excellent alternative, however would be a carb off a 300ex. It is 32mm just as the Lakota's and has the coveted accelerator pump.
Old Aug 7, 2004 | 12:26 AM
NEWDUCK's Avatar
i bought a 36mm for my lakota and had to buy a mojave manifold and now i have to moddify the throttle cabble to fit into the slide. i thought the 400ex was like a 38 or was i dreaming.
Old Aug 7, 2004 | 01:14 AM
Mohawk's Avatar
I have a 400EX carb on my Lakota and yes it works great and yes it is highly moded.On a stock or almost stock Lakota a 300EX carb is great.Yes I did that one also before mine was done all out.
Old Aug 7, 2004 | 03:51 PM
MojaveMoron250's Avatar
The 400ex carb is 36mm. When I do a set of hot cams, I will do the 400ex carb swap.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
John Boy
Jul 13, 2015 11:16 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
yambam13
Jul 4, 2015 01:49 PM
