DG Holeshot Module ON/OFF switch
Old Jan 4, 2004 | 05:44 PM
650Pilot's Avatar
Default DG Holeshot Module ON/OFF switch
Does anybody know if all the DG Holeshot Module's now come with an on/off switch or is it an option, or an add on?
03 Prairie 650 Advantage camo
2500lb Warn Winch
Old Jan 4, 2004 | 09:16 PM
Prairie700's Avatar
It's still an option for you to buy and add. The instructions for adding a switch are very simple, and the switch is probably under $3 at radio shack.
Old Jan 4, 2004 | 11:25 PM
rutwad's Avatar
IMO, you do not need a switch. The power is not THAT severe.
Old Jan 4, 2004 | 11:37 PM
MikeyBoyesq's Avatar
I have a switch on my P650 for the DG holeshot. It is an option and you have to go find the correct switch yourself. My local radio shacks didn't carry the right kind, so I drove all over Houston to find it at a specialty electical supply store. I seem to recall its a SPDT switch and its the "on/on" type of switch (b/c you need to send either the stock speed sensor signal OR send the DG holeshot signal). An "on/off" switch is NOT what you need and that's the only kind of SPDT switch they had at my local radio shack. [img]i/expressions/face-icon-small-sad.gif[/img]
The right switch only cost me about $2.50, so I bought 3 of them in case they get corroded in time and need replacement. I couldn't find a waterproof switch that would work as that would be the perfect set up.
For most riding situations, I totally agree with Rutwad's statement above that its not necessary to install a switch. Basically, I use the switch whenever my kids or wife drive my quad (especially on pavement). I also use it when I do steep, rockclimbing. I tend to go up these rocky hills very slowly and sometimes I hit WOT to get past/over a tough obstacle...that's exactly the time when I don't want a DG holeshot to come on! Other than these 2 situations, the switch is always in the "on" position and thus, is not needed. The neat thing about this switch is that you can turn it on or off while the engine is running, so its very convenient. I even mounted mine on the handlebar plastic next to the speedo display and it looks like OEM.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 5, 2004 | 10:21 AM
prairie633's Avatar
The rumor is that the next version of the DG Holeshot will have a sealed switch on the device.
Old Jan 5, 2004 | 11:27 AM
650Pilot's Avatar
Thanks for all the good info!!
650Pilot
2500lb Warn winch
Holeshot Module (on the way!!!)
Old Jan 14, 2004 | 06:44 PM
PrairieDeerHunter's Avatar
Highlifter module is in Today.They will ship out today or tom.
Can someone tell me how to do a switch on it. What kind etc........
Once I have it set up I will post how it works.
Thanks
Old Jan 14, 2004 | 06:52 PM
PrairieDeerHunter,
I answered your question on the other post ("HL Module") in this forum.
pgamboa
Dec 24, 2023 11:52 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
nick c
Sep 13, 2015 10:08 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
toonces
Sep 5, 2015 01:14 PM
