bore size
Old Jan 4, 2004 | 09:04 PM
brian14's Avatar
Default bore size
what does bore size mean? ive been considering boring my warrior i dont know whether i should bore 1,2,ore 3 over..and what exactly does that mean??
Old Jan 4, 2004 | 09:25 PM
MOJAVE02's Avatar
Default bore size
heres the thing dont bore unless you have scoring on your cylinders that cant be honed out. on this air cooled motor you wont gain any horsepower at all you will just overheat. usually the piston manufacturer makes piston sizes in .020, .040, and .060++++ so on. some consider .020 1st over bore then .040 2nd overbore and so on. but dont bore, you want a few more ponies outta the warrior put on a slip on exhaust, change the airfilter, and change the cam. if you wanted to get into the internals get a stock bore high comp piston, oil cooler, port/flow the head and do a 3 way valve job. save your bores for later do not waste and overheat.
Crotts's Avatar
Default bore size
bore size goes in this order
.020" over
.040" over
.060" over
.080" over
You really dont see that much of a gain unless you go big. .080" is the max bore for your sleeve, but if you go that big and something happens that damages you sleeve you will have to resleeve your jug.
Levi Enstad
Sep 26, 2015 08:00 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
