p700 muffler removal
Old Jan 4, 2004 | 09:16 PM
DaRiot's Avatar
Default p700 muffler removal
What is the easiest way to remove my muffler? It seems the rear cylinder's header is not removable from the can. I just couldn't reach the nuts. Short of removing all sorts of plastic I tried to weld, grind, and paint on the muffler while on the quad. Now in order to make it look like it was done at the factory I need to do it right.
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 9, 2004 | 08:57 PM
DaRiot's Avatar
Old Jan 9, 2004 | 09:26 PM
n2xlr8n's Avatar
Originally posted by: DaRiot
What is the easiest way to remove my muffler? I need to do it right.
In order to facilitate the removal of the rear exhaust flange, you will have to remove the plastic. I approached it from the driver's side. HTH
Steve
Old Jan 9, 2004 | 11:19 PM
DaRiot's Avatar
Just the black plastic or the entire side?
Old Jan 10, 2004 | 08:02 AM
DaveK3131's Avatar
If it's similar to the 650 which I think it is....just jack up the backend and take off the right rear tire ( facing it from the front) and then you can reach in there with a long extension and a universal swivel and spin the nuts right off......be careful don't lose the gasket........I changed mine pretty easy that way without taking any plastic off except the seat for light.........Dave
Old Jan 10, 2004 | 08:35 AM
DaRiot's Avatar
Thanks
Old Jan 11, 2004 | 06:47 PM
rutwad's Avatar
You should not have to remove the plastic. It may make taking off the exhaust easier, but you have to deal with taking off the plastic, and putting it back on. Try using a wrench coming from the top (under the seat) or either a universal swivel thingy (pretty sure that is technically right) and a loooong extension coming from near the muffler itself. Hope this helps.
Old Jan 11, 2004 | 07:02 PM
Prairie700's Avatar
I removed all the back plastic, to make it a whole lot easier to get to the exhaust bolts on the rear cylinder, and remove the rear shock.
It only takes about 10 minutes to remove the rear plastic, and it makes the whole job so much easier.
It's really only 6 fasteners for the rear rack, and 6 for the entire back plastic.. Oh yea - you have to remove the gas cap too.
Reminder: Don't forget to unplug the rear tail light.
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
