Pred 90 throttle cable
Old Jan 6, 2004 | 01:00 AM
csamayfield55's Avatar
Default Pred 90 throttle cable
Has anyone here had any problems with the throttle cable sticking on there Polaris's? my sons 3 week old 90 has done it twice now and is in the shop for a replacement. I thought that it would shut it off if the throttle hung open? It didn't on his and he thankfully had enough sence to reach up and flip the key before it got out of control. Also one of the tie rods went bad on the steering linkage already and he only has about 4 tanks through it.
Chris
Old Jan 6, 2004 | 11:10 PM
spike99's Avatar
No throttle cable sticking problems with our '03 Pred-90. In our cold weather, our front brake cables are always freezing up. With lots of gaseline antifreeze (injected down the top of the brake cables), they free up within 5 minutes. If you live in a "below freezing" climate, you may want to use gaseline antifreeze or car door deicer fluid as well. If in a warm climate, many people use WD-40 as lubrication fluid. Many say it helps - especially after they remove their factory oil injection system's 2nd spring.
Hope this helps...
Old Jan 11, 2004 | 08:10 PM
well I got it back on friday they replaced the throttle cable but said the problem was a bit of dirt in the carb slide got it stuck. Now how in the hell did it get in there???
Chris
Old Jan 11, 2004 | 09:53 PM
spike99's Avatar
If there was dirt there, hard to imagine how it got there. With cables, even a small grain of sand can make things very dangerous within a second.
Do you think they were BSing you??? Some repair shops don't know what a problem is, so they replace everything related to that area, then blame it on a part "they" feel may have been defective.
Regardless, sure hope they've cleared the problem and your throttle cable works properly now. Properly working throttle cable is sometimes more important that brakes.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
sleepyva
Sep 2, 2015 06:32 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
