Cycle country snow plows on a p360
Old Jan 6, 2004 | 09:16 PM
idaho1's Avatar
Default Cycle country snow plows on a p360
Anyone else had to replace floorboard shockmounts after installing a cycle country plow?? I am eating them up due to the placement of the plow mounting brackets.
thanks
Old Jan 7, 2004 | 12:54 AM
03P360's Avatar
My rubber mounts broke way before I even got a plow. I used a simple fix and haven't had any problems for a long time. I went to Big R and got eight small bolts(not sure of the size, 8mm maybe) with nylon lock nuts and some washers. Next I drilled the center out of the rubber part of the shockmount. After that I just reassembled so that the floorboards are basically bolted solid to the frame while the rubber piece acts as a spacer. I didn't notice any more vibration in the floorboards after this than before and like I said, It worked great and was a hell of a lot cheaper than those shockmounts are. Hope you get yours fixed.
buddieboy
Dec 9, 2016 05:50 PM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
awer1968
Sep 8, 2015 11:02 AM
