lt 80 bushings
Old Jan 6, 2004 | 11:20 PM
kendaLt80's Avatar
Default lt 80 bushings
i was getting ready to take all of the bushings out of a arms and motor mount and was wondering if anyone has done this and could tell me the easiest way of doing it? do they sell any aftermarket bushings to replace them with thanks for any replies!
Old Jan 7, 2004 | 12:26 PM
LT80's Avatar
LT80 Expert
I've seen some mighty wore out LT,s and I've never seen a-arm bushings wear.I'm talking the bushings that bolt to the frame.
If your talking the spindle bushings: Just pull apart and replace the long tube.
The motor bushings are a lil more work. I prefer to remove the motor and heat the aluminum. Then press/drive the old bushing out. Reverse to install.
Suzuki sells the bushings. Haven't seen a replacement. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 7, 2004 | 04:56 PM
spoolnaround's Avatar
I did this when I first bought the boys bike, those little buggers are a PITB!
Old Jan 7, 2004 | 09:53 PM
kendaLt80's Avatar
well i must remove them im getting everything powdercoated and for them to bake the finish i must remove all rubber parts?? i hope its worth it? lol
Old Jan 8, 2004 | 08:49 AM
fastfredy's Avatar
kendaLt80, if you dont mind me asking what are you paying to have it powdercoated and what will it help on the lt.
Old Jan 11, 2004 | 10:17 AM
kendaLt80's Avatar
im getting everything on the little lt powdercoated it dont help anything but give it a coustom look?? as for the price i have a friend that owns a buisness and i got it cheap......traded a little ac and heat work.......if anyone needs a part powdercoated pm me and i can get u a price thanks
Old Jan 11, 2004 | 12:33 PM
LT80's Avatar
LT80 Expert
The benifit to powdercoating is:: it is easy to clean. You must wipe/scrub on painted surfaces. The dirt on pwdercoating seems to fall right off with a garden hose.
I'm wondering just how hot the bake oven gets. The rubber stuff will take a good amount of heat.
Old May 2, 2016 | 02:42 PM
DirtDevil101's Avatar
400 degrees for 10-15 min. is the norm. It really depends on the rubber if it will survive or not. The cush-drive on my Vmax (similar) survived two heat cycles before showing signs of heat damage...but that's the exception and generally not the rule. I'm PC'ing my son's LT and yes, I'm removing the rubber bushings...melted rubber make a nasty & toxic mess :P
Also, aluminum casting tend to be very porous...so I generally use an extended outgas cycle about 25 degrees higher than cure temp...so you're looking at 425 degrees for like an hour or so...
Frank
Old May 6, 2016 | 07:58 PM
kave's Avatar
I pressed the bushings out when having frame powder coated. It's been awhile but believe I used a deep socket for pressing the bushing out and another deep socket to press the bushing into. Today, I would turn the cylinders to use for pressing.
I tried several methods but the press was the only one that worked.
I paid ~$300 for frame and four rims to be powder coated.
Old May 10, 2016 | 11:39 AM
Yeah...I have a home-made bushing/bearing press...basically 2 sockets connected by a high grade bolt and thick washers...the smaller socket end will just fit on the outer edge of the bushing/bearing to be pulled, but smaller than the hole it seats in...the larger socket will be just larger than the exit hole...align carefully (you can heat around the bearing/bushing to aid in removal), then hit it with an impact gun...works like a charm...even on those tough engine case frame bushings...the push/pull action will ensure no cracked parts/cases...
$300 is a decent price and really depends on condition of the delivered parts as well as coats (base vs. base + clear)
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
cdstang
Aug 31, 2015 07:52 AM
