Big Bear NOT Starting
Old Jan 9, 2004 | 11:42 AM
Jarod's Avatar
Default Big Bear Starting
my bear wont start, the choke line is frozen solid, we just got a lot of snow, it is in the single didgets for temperature, it just cranks and cranks, i got a few pops out of it but it just wouldnt stay running, any suggestions??
Old Jan 9, 2004 | 11:46 AM
BigBearFX's Avatar
Default Big Bear NOT Starting
my wolvy took a fer ever to start yesterday. i sprayed some started fluid and a few seconds later it fired right up. as fer choke line i dont know
Old Jan 9, 2004 | 11:51 AM
BigBearFX's Avatar
and im guessing you have it in your nu shed so i imagine it gots pretty cold in there
sAyIt_fmf's Avatar
can you get to the airfilter pretty easy on that machine? (I'm not very familiar with it)
If you can...partially cover the air filter until it gets warmed up...
Old Jan 9, 2004 | 11:56 AM
BigBearFX's Avatar
yeah he can try that jarod
Old Jan 9, 2004 | 01:47 PM
HoundDog06's Avatar
I your choke line is frozen, try using a hair dryer to warm up the carb and then remove it and clean the corrosion/water etc from it. Apply a little bit of lithium grease when you reinstall it to keep it from refreezing.
~HoundDog
Old Jan 9, 2004 | 04:18 PM
sn0wrider's Avatar
Get a blowdrier and use it on whatever u said was frozen, i do that all the time..
Old Jan 9, 2004 | 11:26 PM
BigBearFX's Avatar
if all else fails. go through the humility of having your brother tow you with his 250 timberwolf and have it thaugh out in there nice heated garage. id leave it there till it warms up.
Old Jan 14, 2004 | 02:54 PM
Jarod's Avatar
hey thanks for the replys, my bro told me to do what sAyIt_fmf said, so i did, it starts now but the shift lever is froze, so i have to work the lever for a while for it to free up then its smooth sailing er... sliding!!
slides great!!!!!!!!!
bbfx, good suggestion, will go try now j/k,lol
thanks again everybody
Old Jan 14, 2004 | 02:58 PM
Jarod's Avatar
hey i also tryed climbing a hill covered with like 1.4 ft of snow, great fun, didnt get stuck, came fairly close but i always made it
