NEED HELP!!! '99 500 Mag. with an electrical problem
Old Jan 10, 2004 | 01:47 PM
RedRinconRider's Avatar
Default NEED HELP!!! '99 500 Mag. with an electrical problem
I have a '99 500 Magnum that will not start unless you hold the throttle a little bit to disengage the ETC. It also will stall when you put it in reverse unless you hold the override button. Any ideas on what to check would be helpful.
Old Jan 10, 2004 | 04:41 PM
DaveMaxx's Avatar
When you say "will not start" do you mean the starter does not turn over or it turns over fine but will not fire?
Old Jan 10, 2004 | 05:14 PM
It spins over fine and will run if you rest your thumb on the throttle to break the contact on the ETC. As long as the ETC does not make contact it will run great until you put it in reverse then it dies unless you have the override button pushed.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
