i need help with timing.
Old Jan 10, 2004 | 10:43 PM
thebigshow's Avatar
Default i need help with timing.
i jst got my bike back together and its kind of hard to start and it lags a little.im guessing i didnt get the timing chain back on the cams right.do any of you all have any suggestions on getting it timed right? Thanks
Old Jan 10, 2004 | 11:24 PM
PUSHINTHELIMIT's Avatar
Yep, sounds like you got it off 1 tooth. after you get the valve cover back off and everything, first thing you do is get the flywheel mark lined up PERFECT, and if you got a TDC bolt USE IT! I didn't have a TDC bolt the last couple times I did it and it's a PAIN IN THE a$$ to get it right because the motor could turn over slighty while you're getting the cams lined up! Now if you don't have a TDC bolt, after you get your cams lined up and everything make sure the motor didn't turn at all by checking the mark on the flywheel. And make sure you check if the cams are lined up AFTER you put the timing chain tensioner in because it will move a little bit and can still be off if you don't check it. And make sure you double triple quadruple check EVERYTHING before turning the motor over otherwise you will be kicking yourself in the a$$ after bending some valves from slight stupidity..... LIKE I DID![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 10, 2004 | 11:46 PM
thebigshow's Avatar
how do u know if the cams are lined up?
Old Jan 10, 2004 | 11:54 PM
After you get the flywheel lined up, the cam lobes should be opposing each other and the lines on the cam gears should line up with each other through the chain guide.... Do you have a shop manual?
Old Jan 11, 2004 | 12:02 AM
thebigshow's Avatar
no. but i think im going to get one now.........my cam lobes arnt perfectly opposing each other, they close but there a little off.
Old Jan 11, 2004 | 12:10 AM
Look at the lines on the cam gears to see how far you're off.
Old Jan 11, 2004 | 12:20 AM
thebigshow's Avatar
both lines on both cam gears should be idenical?(if ones facing straight up ...the other should be facing straight up also???
Old Jan 11, 2004 | 12:30 AM
NO NO NO! lol, the have to line up perfectly horizontal through the chain guide (black plastic piece between the cam gears). Man, don't bend no valves...[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 11, 2004 | 12:48 AM
thebigshow's Avatar
pheeeeeeew...lol........u had me worried there for a minute. im going to look at it in the morning. i got about a week to get it lined up.my valve cover bolt should be in by then.................im actually trying to quit learning this stuff the hard way........way to expensive...lol.
Old Jan 11, 2004 | 03:24 AM
Entomber's Avatar
thebigshow,
Take it from me who F--- up a cam (look at last pic in my gallery). GET A SHOP Manual and take yourr time. If ya screw it up it will take longer and more $$$. It will be worth getting one in the end. I take it when you slap it back together your not using torque specs.
