"Priming" oil pump after rebuild - Raptor
Just curious if adding about 1 quart of oil to the crankcase (through the timing chain area) prior to closing up the cylinder head would help get oil to the oil pump upon initial starting.
Seems the oil pump will be totally dry otherwise. The last time I rebuilt the motor it seemed to take a long time for the pump to start pumping oil ( I monitored the weep hole).
Comments ?
Comments ?
I left the head cover off until I got the oil lines connected. Then poured a quart of oil in the top end. The oil pump is submersed in oil at that point. The only way too prime the pump is too turn the engine over. I removed the spark plug and cranked the engine for 5 or 6 seconds before starting the engine. Fisher, what did you wind up doing engine wise? Any rhyme or reasoning as too why the 02 gearset failed?
Gary
Gary
Well I filled the Oil Resevoir up and took the starter cover off and poured about 3/4 of a quart there and turned it over until the battery went dead. I believe it was going on 30 min and still no oil out of the weep hole. I just didnt want to start it until I got oil coming out.
Gary
Yes I did check the banjo fitting and it drained quick so I just think that the oil pump is totally dry. I also took the line off the top of the head and poured oil down it and the hole. Still no go.
