Predator Electrical....Simple precaution
Old Jan 14, 2004 | 12:20 PM
modquad's Avatar
Default Predator Electrical....Simple precaution
Been getting a few e-mails about a couple of stalling Predators. Seems like they just loose electrical power suddenly. Easy fix. There's a small black protective pouch on the LH side of the quad (viewed like you're sitting on it). Inside is a circuit braker. If you've been through some deep water, sometimes that water can seep inside, and cause a bit of corrosion on one or both of the terminals. Just carefully cut open the pouch, to gain access. I've used CRC 2-26 contact cleaner, and/or dielectric grease (you should put a dab of this inside your sparkplug boot also) to clean/protect the connections. You can clean the pouch up, and reseal w/ silicone, or similar sealant. If the corrosion is too extreme, you dealer can get you a replacement. Easy fix, considering all the crap we put these machines throught. [img]i/expressions/face-icon-small-smile.gif[/img]
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
