trailblazer carb
Old Jan 15, 2004 | 08:05 PM
mudmaster250's Avatar
Default trailblazer carb
if anyone has a 34 MM carb from a 400 that they would like to get rid off make a post and i will PM u. im not for sure that i will be able to buy it but i want to get some prices to show my mom thanks scott
Old Jan 15, 2004 | 08:12 PM
tbsleeper's Avatar
does this transition really work??
Old Jan 15, 2004 | 08:18 PM
trailrider500's Avatar
I think the intakes are different sizes not for sure though...
Mudmaster, i would go with other mods before a crab...
Old Jan 15, 2004 | 08:38 PM
Jayblazer's Avatar
yea it works i think 2manytoys has one on his
Old Jan 15, 2004 | 09:11 PM
2manytoys's Avatar
I used to have one on mine. The intakes are very close. If you take some dishsoap it will slide right on. You do have to jet it down. If you dont have any other mods then you will notice much of a gain. You need a pipe to let it breath then a bigger carb would be good. I know it is hard to convince younger peoples parents to get a pipe for tiier quad but it is the pipe that makes the biggest performance gain. second is the porting. Everything else is just a plus. 1 hp here, 1 hp there adds up. you can usually go on e-bay and get them for around 40-50 bucks. Just look under Polaris Scrambler. I see them there all the time. That is where I sold mine. I now have a 36 mm pwk flatside. This carb is awsome but the 34mm did have a good gain.
Old Jan 15, 2004 | 09:30 PM
tbsleeper's Avatar
so 2manytoys it should all go together without any cutting or adding stuff to make it fit?? just a little soap. see one on ebay for $16
Old Jan 15, 2004 | 09:37 PM
2manytoys's Avatar
There is no modification at all just make sure that if you do get a 400 carb that is comes with the brass choke fitting that scraws into the carb. The 30mm fitting will not fit. That is the only part that you have to change besides rejetting.
Old Jan 16, 2004 | 11:03 AM
TWEEKER's Avatar
i also have a 34mm on my tb i chucked it in my laythe and took some off the snout and the other problem is the I.D is bigger than the 30 so the rubber boot is smaller if you stick the 34 on and look into the carb from the back side where the air enters you will see a 1/6 to 1/8 inch difference meaning the rubber boot being to small and making a sharp lip all the way around the carb causing a disterbence i put mine the the laythe and cleaned it all up for a smooth transaction.
Old Jan 16, 2004 | 11:48 AM
fishslab's Avatar
You can get the boot for a Cyclone 250. It is much larger than the tblzer250 boot. Should fix you right up, but it probably costs an arm and a leg at the dealer.
Old Jan 18, 2004 | 10:51 PM
Whuggs1's Avatar
I have a 34mm on our TB, I used the intake manifold from HPD 13.95 I think it was. Also can get the brass fitting from the dealer for 12.00 if needed.
