? for bigbadscrambler-valve adjustment
Old Jan 18, 2004 | 06:21 PM
4464's Avatar
Default ? for bigbadscrambler-valve adjustment
Bigbadscrambler, I had a problem with the timing mark I thought you might be able to answer. The manual says to line up the "T" mark in the timing hole, but for some reason it won't stay lined up with the hole, it keeps moving just past the hole, do you think I could still adjust the valves with this slight offset? any help would be appreciated, Thanks!
Old Jan 18, 2004 | 08:51 PM
ftwflh's Avatar
Take the plug out to keep the compression off it.
Old Jan 18, 2004 | 08:56 PM
4464's Avatar
The plug is out ! The "T" mark just doesn't want to stay visible in the hole, it moves JUST past it.
Old Jan 18, 2004 | 08:58 PM
ftwflh's Avatar
as long as it is close be sure that both sets of valves are shut(slack in both) and set it from there.
Old Jan 18, 2004 | 09:43 PM
BigBadScrambler's Avatar
It is a pain in the **** to get that lined up. But like ftwflh said, just make sure that both valves are closed. It may go a little past, but try your best to get it in the center. I must have taken me 1/2 hour to get it lined up. That "T" mark is on the crest of the cam lobe and is hard to keep it there without going over.
Old Jan 18, 2004 | 10:10 PM
4464's Avatar
Thanks alot for all the info, I appreciate the help, I will go back to the drawing board tomorrow and try to catch the "T" at the top!
Old Jan 18, 2004 | 10:21 PM
Did you remove the timing chain cover? That is easier than looking for the "T" mark. Remove that cover and rotate the engine until the camshaft sprocket locating pin is facing upward directly in line with the crankshaft to camshaft center line. That might make it a little easier
Old Jan 18, 2004 | 10:44 PM
4464's Avatar
I saw the picture in the manual but in the instructions I don't know why that step (remove the camshaft cover) is not written in the steps? but I will remove that cover and line up the marks. thanks!
Old Jan 18, 2004 | 10:56 PM
No problem. I noticed that they forget to leave that part out too. Good luck
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
