Scrambler Primary Clutch Spring Swap?
Old Jan 19, 2004 | 02:28 AM
pulverized's Avatar
Default Scrambler Primary Clutch Spring Swap?
Is there any secrets I need to know to change my primary spring in the Scrammy 500? I know with my V the center bolt was reverse threaded and if I didn't read on here that it was I would've broke it for sure[img]i/expressions/face-icon-small-blush.gif[/img] Any tips would be greatly appreciated[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 19, 2004 | 11:43 AM
fishslab's Avatar
It's real easy. The bolt is not reverse thread. There are Xs on the primary top plate and spider. Keeps these lined up when bolting back together. The clutches are balanced from the factory. The six little bolts on the outside top plate take 90in/lb torque or 7.5ft/lbs. The main bolt is 40ft/lbs. Take the time to blow it all out with an air compressor while your in there.
Old Jan 20, 2004 | 12:12 AM
pulverized's Avatar
Thanks Fishslab,
I'll give it a try and see what I can screw up[img]i/expressions/face-icon-small-happy.gif[/img]
ghost civic
Jan 15, 2020 07:43 AM
austinwhitton
Aug 11, 2015 06:21 PM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
