TEAM secondary help
Old Jan 21, 2004 | 07:14 PM
ftwflh's Avatar
Default TEAM secondary help
I am getting a used TEAM secondary and need to know what it will need to work in a basicly stock 500 Scrambler. Here is what the clutch has in it " It has a 58-44-40 Helix and a
black w/red stripe spring, It origanily was in a scrambler with a Hot Seat
exterminator kit on it, Then I put it in the Trail Blazer with the HPD Race
Mod kit and was told that this setup would be fine, and it seem to work good." I plan on using a Aaen blue spring or a stock silver. what I need to know is will this helix be ok for trail ridding? And advice is welcome. Brad
Old Jan 21, 2004 | 09:14 PM
DustinMinnesota's Avatar
One of the sites I think it is HPD has the rates for the helixes and what they are go for on their site...
Old Jan 21, 2004 | 10:38 PM
CED's Avatar
CED
A friend of mine has the Team secondary and he called HPD on how to adjust it and he was told that there is no adjustment,you can only change the spring.It has no helix,at least not like the stock secondary.
Old Jan 22, 2004 | 12:31 AM
talonhawk's Avatar
The Team rapid reaction secondary clutch has about 5-6 different helix
and cam angle options!
Old Jan 22, 2004 | 02:21 AM
modquad's Avatar
Yea, they are changeable. If your Team clutch doesn't have the two recessed allen set screw adjusters just to the outside of the retaining bolt hole (I know that description sounds funny, but if you have them, it'll make sense), I'd send the unit to HPD. I think Darryll stated for around $40 he'd mod the "not purchased from HPD units". Olav Aaen is a clutching master....but I think on this one, HPD has taken the lead. They'd be a great one to ask about the helix also. I don't remember which one was changed out in mine....sorry. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 22, 2004 | 09:28 AM
CED's Avatar
CED
my friend has the TAS 98 and he was told there is no adjustment on this model.
Old Jan 22, 2004 | 09:03 PM
ftwflh's Avatar
I emailed Hotseat on this and they told me it would work ok on a stocker but would really turn on if I put a pipe and air filter on it.
donintennessee
Jan 8, 2021 12:40 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
1000gade
Aug 29, 2015 10:34 AM
Aug 11, 2015 03:42 AM
