questions about changing the head gaskit on a big red?????
Old Jan 22, 2004 | 07:32 PM
loveotride123456789's Avatar
Default questions about changing the head gaskit on a big red?????
has anybody changed a head gaskit on a bigred 250es . can you just undo the bolts take it out and put a new one on, or do you have to unconnect the valve rods or take out the motor . and when you put a new one do you have to use RTV . and i am afraid that the bolts will strip out the threds because that happen to me when i changed the oil .[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 22, 2004 | 10:14 PM
pinkelephant's Avatar
i did it on a 200 big red. i dont think (not sure) you have to take the engine out, just pull the head and see if you ahve enough room. you shouldnt have to use RTV, it should be fine by itself
Old Jan 23, 2004 | 04:16 PM
do u think that the head bolts will strip out like what happen to me when i change the oil when i took out the oil plug all the threds came out with it?????:
Old Jan 23, 2004 | 05:18 PM
Bulldog250R's Avatar
are the bolts rusted in or just been on there a while? take it sloooowwwww when taking them out or get them part way out and use some penetrating oil on the exposed threads to make the job easier- just my .02- good luck, keep the classics running!
bulldog
Old Jan 23, 2004 | 05:30 PM
no they have just been in there sicne 86 . If the threds still come out do you know a way to fix them????
thank alot [img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-frown.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 23, 2004 | 05:41 PM
WISTECH's Avatar
Is your head gasket leaking oil or losing compression.
Old Jan 23, 2004 | 05:56 PM
it is losing compresstion it only has 75lbs of compresstion and no it is not leaking oil
thank!!!!!
Old Jan 23, 2004 | 06:37 PM
[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Jan 24, 2004 | 04:03 AM
i guess it depends how badly stripped the threads are, if they arent bad, run a tap down the hole (exact same size) to clean the threads out, Im not familiar enough with the bigred to know how its put together on the top side. If the threads come out with the head bolts, a machine shop could advise you on a helicoil to replace the missing threads. I used a helicoil with jb-weld, liquid cold weld, on a stripped rear end alignment hole on my old yamaha 200 tri-moto. good luck!
Old Feb 23, 2004 | 09:49 PM
LittleBehaus's Avatar
I have changed a head gasket on my buddies bigred and we did not take of the engine,
it's a tight fit to get off, but saves time. All you have to do is remove old gasket, clean the
area where gasket goes and pu new one on and be sure to torque the bolts.
85 200x
