Help me out I am stuck.
Old Jan 23, 2004 | 10:27 PM
MudStud's Avatar
Default Help me out I am stuck.
I FINALLY got around to the TBR swing arm. I had the A-Arms installed for 3 months now [img]i/expressions/face-icon-small-smile.gif[/img] Have not rode in 3 months [img]i/expressions/face-icon-small-sad.gif[/img] Anyway, here is my problem. I am installing the carrier in the housing on the SA. I can not for the life of me get that dang C clip that goes on the left side to hold it in and pinch it against the brake mount.
Other then buying a 1 time use expander are there any secrets?
Old Jan 23, 2004 | 11:45 PM
DuneDevil's Avatar
Do you have the carrier out of the stock swing arm?
I am not following you on this, What is SA?
If you do your own bearings (repack in grease) then I would recommend you buying a good set of snap ring pliers. If you ride in mud all the time, these pliers will pay for themselves.
I check my bearings every few rides, so I use mine all the time.
DuneDevil
Old Jan 23, 2004 | 11:49 PM
MudStud's Avatar
SA= swing arm for short.
Yes, the carrier IS in the SA [img]i/expressions/face-icon-small-smile.gif[/img] I just cant get that snap ring on..
Ok, I did regrease them I might just have to break down and buy the tool....
Old Jan 23, 2004 | 11:53 PM
DuneDevil's Avatar
Doh [img]i/expressions/face-icon-small-blush.gif[/img] I should have known that....
DuneDevil
Old Jan 24, 2004 | 03:15 AM
BlackHawk's Avatar
Grady,
When you get that setup installed and working I wanna hear about it after you've rode it for a couple of hours. I'm liking the idea of some goodies and I might look into a +2 swingarm after I get the 46HV installed in the distant future so I wanna hear how well the TBR setup works.
Old Jan 24, 2004 | 08:46 PM
MudStud's Avatar
I got the snap ring expander and its on now... Now my chain is to long for the swing arm [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 24, 2004 | 08:53 PM
ironrod's Avatar
Rule of Modifications #1: Make one mod, and make 2 more to make the first one work.
BlackHawk's Avatar
So you have the stock chain, and when you went from the stock swingarm to the TBR, the chain is now too long? I assume you got the 'stock length' swingarm, right?
Old Jan 24, 2004 | 08:57 PM
QUADMAN650's Avatar
-1
Old Jan 24, 2004 | 09:25 PM
MudStud's Avatar
Yep -1
Now, Should I get a chain or a link puller???
I truely hate pulling the swing arm..
