250ex wont start
Old Jan 26, 2004 | 03:28 PM
Eric250EX's Avatar
Default 250ex wont start
my 250EX will not start, charged the bat and it still wont start. i put the choke on and it wont start. it doesn turn over either. i was riding in the snow today and it was fine then it just stalled out and couldnt get it to start since
Old Jan 26, 2004 | 03:33 PM
Eric250EX's Avatar
bumb
Old Jan 26, 2004 | 03:47 PM
hondabuster's Avatar
How much volts in the battery? Tried to pull start/tried to push start? Do you have a primer button on the side of the carb? If it doesnt turn over, you need to recharge the battery and load test it. If you can...get it in the garage and heat it up, that will also dry it out.
Does it have spark when you pull start?
Kill switch on?
Old Jan 26, 2004 | 04:32 PM
Eric250EX's Avatar
it turns over now, i charged the bat it just wont start up. with or without the choke id doesnt start
Old Jan 26, 2004 | 05:24 PM
Eric250EX's Avatar
any ideas? heeellppp
Old Jan 26, 2004 | 06:34 PM
I know every time i have a stubborn quad, and it wont start, the easest way to get it going is to have someone pull you with a tow strap, to bump start it. Just have them pull you about 7 mph and leave yours in 4 th gear....if its capable of being started it will.
Kyperman's Avatar
Change the spark plug.....put a brand new one in....start with basics first....I bet a new plug makes it start right up.
Old Jan 26, 2004 | 06:37 PM
Eric250EX's Avatar
ok ill switch the spark plug, but how would it start...put it in forth but where will u get the spark?
Old Jan 26, 2004 | 06:44 PM
Kyperman's Avatar
Does it backfire when you try to start it....with or without the choke on.....also, turn off all the lights in your garage and look into the spark plug hole when you try to start it....you should see blue light if you have any spark....
Old Jan 26, 2004 | 07:09 PM
Eric250EX's Avatar
doesnt back fire, doesnt even start, ill go check for a sark now. its electric start with not kick/pull back up. all it does is make that noise when u press the start button
