what is this on my 400 sport tranny
partsland pic
what is the stud number 5 for also what number would be the bolts that seal the case because i am missing one. one more thing there are three holes in a triangle pattern and the stud fills one of them should there be studs in the other two???
First, the case bolts are #7, they are 1/4 - 20 thread with a 3/8" head. You can get away with a normal 1/4 - 20 bolt with a 7/16" head in some of the spots, all the case bolts are the same, so you just have to shuffle them around to accept a spot the 7/16" head fits.
#5 Stud is part of the speedo gear attaching system - Polaris used the same tranny cases for a lot of different models - some had the speedo option. The other 2 holes there are also part of the means to attach the speedo gear housing.
Sep 30, 2015 01:37 AM
kampswas
Sep 23, 2015 05:05 AM
