Jetting Help For a 400EX
Old Jan 26, 2004 | 10:29 PM
huskerjim's Avatar
Default Jetting Help For a 400EX
I just tore down the 400ex I'm adding a 11:1 Wiesco piston stock bore Shaving the head 10 thousandths 5 angle valve job Stage two cam hot cams, heads flowed and exhaust and intake I have a W/B Pipe K&N Lid off What is your suggestion for Jets and please only expericed Builders and riders answer please I ride about sea level about 4500. Run 112 OC gas, any suggestions will I need to mess with idle needle as well as the jets, I ran still a little rich with stock jets with the pipe and K&N at this 4500 sea level. help want to start off with a close match.
Old Jan 27, 2004 | 12:03 AM
TractorPacker's Avatar
Do you have a balloon?
40 pilot, raise the needle one and start with a 160 or 165, that should get you close enough to aleast break in the cam and piston.
Old Jan 27, 2004 | 03:28 PM
cals400ex's Avatar
that seems like a good start.
i assume you ride at an elevation of about 4500 and not at sea level?
Old Jan 27, 2004 | 03:31 PM
huskerjim's Avatar
yes 4500
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
