One way Raptor?
Old Jan 26, 2004 | 10:30 PM
Punker660's Avatar
Default One way Raptor?
I went to Glamis this weekend and my bike wasn't itself. First of all, my starter makes a loud "click" sound that can't be good. It also spins as if the motor is already running. I've never heard this before. Secondly, My clutch or tranny is acting up. When opening it up only, shifting from gear to gear, the bike revs as if I'm feathering the clutch but I'm not. It revs real high before finally settling into the next gear. The clutch is slipping. Also, what jets should I be running at Glamis. I didn't change anything from where I normally ride (Phx, AZ area). I have no idea what's going on any help or comments would be sweet.
Are these the symptoms?
Old Jan 26, 2004 | 11:09 PM
RaptorOwner's Avatar
Your one way is out you need to change that ASAP and your clutch is slipping, you might take out the plates and bead blast them and look at the clutch plates and see if they are worn to or below specs.
Glamis- You are below sea level so you will have to richen up, my bike ran so lean it looked like the pipe was sand blasted from the inside.
Old Jan 26, 2004 | 11:31 PM
Punker660's Avatar
Thanks Raptorowner, I'm glad somebody finally helped me out. I'm going to fix the problems right away and sell this thing. I might switch sides. Punker450r has a nice ring to it.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 27, 2004 | 12:44 AM
HazzardCounty's Avatar
Don't give up just yet, your one way is out. Go to www.raptortrannny.com, and the have detailed info on the swap. Get a L&A one way, they are tons better and you'll never have a problem with the one way again, as long as you put the new gear in also. If you don't put the gear in the one way will just go out again. Put a clutch inand your ready to go.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
