dura blue wheel spacers
Old Jun 30, 2000 | 08:50 AM
hondatrx300ex's Avatar
I plan on putting some of these on the rear of my 300ex. I see ther are 2 different kind though. there are the graphlite and the EZ fit. what is the difference? I just want whichever is stronger. thanks,Jake
Old Jun 30, 2000 | 10:34 AM
atvrider300ex's Avatar
i have the DB wheel spacers on my front wheels, not the ez fit type, takes about 45 min. to put on, i like them, i don't tip quite as much
Old Jun 30, 2000 | 10:53 AM
gregsims's Avatar
When you order them, the dealer should tell you which one is for your bike. EZ fit have stud extenders that go onto your existing studs. You should be able to install them in ten minutes. Most 4X4 atvs use the EZ fit. The graph lite use bolts and nuts and replace your existing studs, and this is usually used on sprot bikes. The take a little longer to install.
I have ez fits on my SP500. This is how it was explained to me.
Greg
Old Jun 30, 2000 | 01:08 PM
Skunky's Avatar
I am getting durablue wheel spacers also and I called Durablue Directly. They said that the exzit are a litte better because you do not need to remove the pressin stud... This allows the e-z fits a ,humm how should i say, rest on the stud. while the graphlites you have to take the stud out. The are both made out of the same material... check out www.durablue.com
Actually I should be getting them today.. WHOOO HOOO!!!
O ya the guy said he has never heard of one braking unles you stack them...put more than one on each wheel..
Darn I didn't get them today
Old Jun 30, 2000 | 02:43 PM
philzie's Avatar
I had DuraBlue Graphlite spacers on my Blaster. They lasted about 2 months before they cracked. I got a set of aluminum ones for my 350X, They never btoke, but I Bent my stock axle when I clipped a tree.
Old Jun 30, 2000 | 03:06 PM
Skunky's Avatar
where did you gett the aluminum ones at?? what brand??
Old Jun 30, 2000 | 03:16 PM
gregsims's Avatar
The only time I have ever heard of the Durablues cracking is when they were installed improperly. You have to be careful to completely bottom out the stud extenders.
Greg
Old Jun 30, 2000 | 03:33 PM
Skunky's Avatar
Old Jun 30, 2000 | 04:08 PM
so the EZ fit ones are better? are they as strong as the other ones? they are higher but oh well. later
Old Jun 30, 2000 | 07:32 PM
philzie's Avatar
Both sets of mine required me to punch out the studs, and use long bolts to hold the whole thing on.
I got them mail order. I think it was from Dycorp. I am not sure though. I thought the Aluminum ones were DuraBlue. They were exactly the same shape as the Blaster graphlite, so I just assumed they are DuraBlue.
