WArrior probs
Old Jan 27, 2004 | 05:43 PM
shlekter's Avatar
Default WArrior probs
what would happen if the cam chain gets stretched ... what are the symtoms?
Old Jan 27, 2004 | 05:53 PM
JakalWarrior's Avatar
Uh.... the lines on the cam sproket and head dont match up when the crank is on TDC (they can be a bit off but a lot can signal chain stretch). If its retarded you lose some torque and gain some hp, vice versa if its advanced.
Old Jan 27, 2004 | 06:18 PM
shlekter's Avatar
it is making a noise like the chain is hitting and when i go to rev it up it gos about half rpm and backfires slow down kees running but doesnt go up all the way
Old Jan 27, 2004 | 06:19 PM
shlekter's Avatar
it sounds like the noise is every stroke or every rotation
Old Jan 27, 2004 | 06:33 PM
pull off the timing chain cover and see if its tight on the sprocket then turn the motor over with a wrench while watching and listening to the chain. It might be something wrong with the cam chain tensioner. Check the alignment with the timing marks while your in there and make sure the chain isint loose.
Old Jan 27, 2004 | 07:24 PM
shlekter's Avatar
uh how tight should the chain b?
Old Jan 27, 2004 | 08:51 PM
KILLERCUDA's Avatar
Tight enough so it doesnt move side to side just like your primary drive chain. And tight enough so it barely lifts off the tooth of the sprocket.
Old Jan 27, 2004 | 09:32 PM
shlekter's Avatar
im taking it to one of my dealers sometime this week then if its not over 400 to fix im trading it in at my other dealer and getting a 250
shlekter's Avatar
thanks alot
Old Feb 4, 2004 | 10:08 PM
supertrapp04's Avatar
I was told that the chain had to have at least 1 inch of travel so when u take a jump that the suspension has to traavel causing the chain to tension. so u might not want it to be too tight or u will stretch ur chain.
Supertrapp
87 warrior- supertrapp pipe, k&n filter
