.425" Web Cams -> .412" lift WTF!
Old Jan 28, 2004 | 12:37 PM
ScoobyDFW's Avatar
Default .425" Web Cams -> .412" lift
I measured my new .425 web cam 109's and they measure .412" lift. This is ridiculous!
Old Jan 28, 2004 | 10:54 PM
ironrod's Avatar
Default .425" Web Cams -> .412" lift WTF!
[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jan 28, 2004 | 11:01 PM
sixsixT's Avatar
How did you measure them?
Old Jan 28, 2004 | 11:03 PM
ironrod's Avatar
Do you have a RWR .425 cam to compare it to?
Old Jan 28, 2004 | 11:18 PM
ThePunisher's Avatar
Marky, Ron Wood gets there cams from Web so I would imagine it would be the same.
Old Jan 28, 2004 | 11:35 PM
ironrod's Avatar
Exactly! - but if they are the same, then there would be a problem with the way they were measured, not a problem with the cam. Troubleshooting 101.
Old Jan 28, 2004 | 11:52 PM
sixsixT's Avatar
If the cam has a long duration you may not be able to cross measure the cam itself with a mic, you would need to either install it or put it in a v block and measure it with a dial indicator.
Old Jan 29, 2004 | 12:07 AM
ironrod's Avatar
Tic Toc
Old Jan 29, 2004 | 12:44 AM
XR650Warrior's Avatar
This seems to be a trend with Web Cams, on my XR650 Warrior the specs. are nowhere near what they say it should be. [img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 29, 2004 | 11:09 AM
ScoobyDFW's Avatar
they are from web.
i measured them using calipers, the same way i measured the stock cams. the stock cams measured correctly this way. the duration isn't huge on these web cams. web says to use the dial indicator method also, but i still think they will fall short of .425".
