300ex mods
Old Jan 28, 2004 | 04:19 PM
03TRX300ex's Avatar
Default 300ex mods
Ok i have an 03 300ex and was looking for some good sites and parts for it. Can anyone help
Old Jan 28, 2004 | 05:38 PM
merb's Avatar
Default 300ex mods
first off get them stock tires off the back. i use razor tires they are a flat tire and will help you on holeshots and still can ride good wheelies. then k@n air filter will give more power .change you head pipe and end pipe at same time go to a bigger main and piolt jet pip kit will tell you what size jets to use. after you get these things take air box lid off if running k@n air filter.then just hold on.good luck
Old Jan 28, 2004 | 05:48 PM
BRAD14's Avatar
Default 300ex mods
i run a White Bros pipe and header,uni airfilter,i cut a hole in the part of the airbox closest to the carb(helps keep it cleaner than at the other end)and jets,as for tires i run 20in Titan Fast Trekkes on back and 21in Fast Trekkers on the front,if your looking for more top end i would not run a small tire like a 20in.the fast trekkers hook up great(better than Razrs or Holeshots but if your racing run Razrs cause Holeshots suck.
Old Jan 28, 2004 | 06:01 PM
BRAD14's Avatar
Default 300ex mods
oh yea and buy from magicracing.com
Old Jan 29, 2004 | 04:20 PM
03TRX300ex's Avatar
Default 300ex mods
thanks guys
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
