which year 250r?
Old Jan 29, 2004 | 01:29 PM
madhatter801's Avatar
Default which year 250r?
I am thinking about getting a 250r and I am just wondering what would be the best year to look for.
Old Jan 29, 2004 | 01:34 PM
pimp250r's Avatar
im assuming you mean the trx..so it can personal preference if you like
the 86's are short rods, 87-89 are long
86-87 are blue, 88-89 are red
lol
and I think the 86 may have a higher redline rpm than the others...
other than that I dont know the other differences..
anyone else out there can help this guy out?
Old Jan 29, 2004 | 01:37 PM
your correct, i am refering to the trx
Old Jan 29, 2004 | 01:38 PM
pimp250r, do you race in WI?
Old Jan 29, 2004 | 03:48 PM
pimp250r's Avatar
I was planning on it, my trx needs a bit of work though. As of right now, my base gasket leaks, the valve core in my back right tire leaks air, I need a new exhaust manifold gasket and my exhaust needs to be remounted. I wanted to race ice this year real bad but with those things wrong I couldnt...so ill prolly race this fall when it starts again
Old Jan 29, 2004 | 04:51 PM
Rudedog's Avatar
86-87 are blue, 88-89 are red??????????
Wasn't it..........????
86 white fenders, red: tank, nose piece & seat.
87 white fenders, Blue: tank, nose piece & seat
88's are all red
89's are White fenders red: tank, nose piece & seat
Rude Dog
Old Jan 29, 2004 | 04:54 PM
cRazyJ's Avatar
88's come with a mild port stock
Old Jan 29, 2004 | 07:34 PM
dragracer789's Avatar
LMAO ALL TRX's are orignaly red. You can buy any color plastic for them, but stock its red. 86 had a slightly diffrent frame. there was more to it and it was more sterdy. 87-89 had a bridged intake. All R's have a CDI limiter of 9300 RPM. But sence the R's electrical system is a resisitor type it will not get that far unless you buy an aftermarket cdi. (ie. LRD ultimate rev) 86-87 had a diffrent tranny and also diffrent sprokets. The top gears were slighly taller. But not noticable. The port maping was diffrent between each year. The 86-87's swing arm was steel and 2 inches longer. the a-arms also went forward a little more than 88-89. If you dont really know much about the R cylinder you wouldnt be able to notice the diffrent proting. Thats all the most MAJOR changes between years, but as for witch year is the best.... There all good IMO. There isnt really a hudge diffrence between them so I think you would be pleased with any year.
If you need more changes between the years Ill tell you them. But there real small (I.e jetting, spark plug, stuff about the sleeve ect.
Old Jan 29, 2004 | 07:53 PM
thank you all for your help!
Old Jan 29, 2004 | 07:56 PM
BlueBus's Avatar
All 250r's were not originally red. They all had red in them but that wasn't the primary color. In fact the very first one (86) was white and so was either the 88 or 89. 86 did have a more beefed up frame but is was more prone to cracking. The 86-87 swingarm was only 1" longer which is why you see so many -1" aftermarket swingarms available. The 88-89 were the ones with the a-arms forward. For 88-89 basically the whole center of gravity was moved back an inch. 88-89 is supposed to handle better because of the shorter swingarm and a-arms an inch forward so it is the choice for mx. You can easily achieve the same setup on an 86-87 with a -1" swingarm and +2+1 a-arms. I have an R for sale if you're interested. $4800
http://www.imagestation.com/album/?id=4287848531
