Lectron Carb. questions
Old Feb 15, 2004 | 06:44 PM
Never2High's Avatar
Default Lectron Carb. questions
Does anyone know how to rejet this carb. fouls plug,floods,runs rich some one said that Lextron had 5 built in jets
Old Feb 15, 2004 | 08:21 PM
mojaveaddict's Avatar
The lectron has no jets to change. It is set by the metering rod. To lean it you need to lower the rod. You may need to change the rod if you can not lower it to a place where the mixture is right. Various metering rods are available. Check out this site: http://www.lectronfuelsystems.com/rod_adjustment.htm
You have to make sure the flat side of the rod faces the engine. Lectron carbs are really easy to adjust.
Old Feb 15, 2004 | 09:00 PM
Never2High's Avatar
Thanks that was a easy fix
John Reed
Sep 9, 2015 03:46 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
MooseHenden
Sep 6, 2015 04:24 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
