mojave owner need help
Old Feb 15, 2004 | 09:16 PM
mojavecan's Avatar
Default mojave owner need help
Is there someone that can help me?? I want to know if I can get out my mojave motor with out getting anything off the motor.
thanks for help
Old Feb 16, 2004 | 08:32 AM
toyaddict's Avatar
I have taken mine out several times, if I remember right you have to bring the back of the trans out slightly ahead of the rest.
01 mojave
fst 411
fst cams
fst cdi
supertrapp race pipe
maier black race cut
Old Feb 16, 2004 | 01:25 PM
mojaveaddict's Avatar
You will have to take the kick starter off, The reverse cable loose, drain the radiator and take the hoses loose, Take the exhaust loose, the throttle cable loose, and the left foot peg off. you should then be able to get it out the left side
Old Feb 17, 2004 | 08:25 AM
mojavecan's Avatar
Do I have to take of the chain??
thanks guys
Old Feb 17, 2004 | 09:35 AM
You can loosen the chain enough to get it off of the sprocket in the frt. Then when you remove the swing arm bolt and slide the swing arm back the chain will go with it. If the chain will not loosen enough the easiest way is to just take the frt sprocket off.
Old Feb 18, 2004 | 12:03 AM
mojavecan's Avatar
i will finish taht during the week. hey mojaveaddict I read in a old post that you were planning to do a web site for the MOJAVE, is you're alive or you never start it.
thanks
Old Feb 18, 2004 | 09:34 AM
Never had time to start it. Too busy building modded mojaves. I just started putting pics of my projects in picturetrail instead. Click on the Greenestreak Racing link below if you have not seen them.
Old Feb 18, 2004 | 09:29 PM
mojavecan's Avatar
i see every of your mojave picture. and i finally get out my motor this afternoon.
thanks
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
