how do i adjust my recon's idle
Old Feb 16, 2004 | 07:24 PM
reconman2003's Avatar
Default how do i adjust my recon's idle
Old Feb 16, 2004 | 07:54 PM
bigojaydog's Avatar
On the right side of the carb if you are facing the handlebars you will see a flat head screw on the carb if you turn it towards the right u will raise the idle turn it to the left u will lower it.
Old Feb 16, 2004 | 10:51 PM
ok
now should i do this with it running to see how high it will be or change it then start it?
Old Feb 16, 2004 | 10:54 PM
bigojaydog's Avatar
Do it when its running so u know u didnt go to high.
Old Feb 23, 2004 | 08:44 PM
im just now changing the oil
will this affect the idle?
Old Feb 23, 2004 | 08:58 PM
phibbsie's Avatar
No changing the oil will not effect the idle but make sure you set the idle after the quad has been running for at least five minutes s it is warmed up.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
