Steering Stabilizer
Old Feb 17, 2004 | 05:37 PM
HiFlyinRaptorRyder's Avatar
Default Steering Stabilizer
I just got my Denton Steering Stabilizer in the mail today and I am wondering how to put it on there. Any help would be great.
Old Feb 19, 2004 | 01:39 AM
RaptorRacer1's Avatar
The stud attached to the stabilizer goes in the hole just under the lower radiator mount hole. Attach this loosely first. The shaft extends through towards the steering stem. The **** to adjust it should stick out the front of the quad. Set the handlebars straight and the wheels straight and put the shaft of the stabilizer 1/2 way though its travel. Position the aluminum mounting clamp on the steering stem so that the hole lines up with the hole in the end of the damper rod. Clamp it onto the steering stem. On mine it was all the way down as far as it could go on the stem just before you get to the hexagonal section. After that is tight, bolt the stem clamp to the end of the damper shaft. Turn the wheels left and right as far as they go and make sure the damper does not bind at all. If it does, adjust the steering stem clamp up or down, or rotate it as necessary to allow full turning without any binding. It took me a while to get it just right. Good luck.
RR1
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
