Over the winter I think the wolvys carb gumed up hEELLPP
Do you think i will be able to clean it without loosing anyparts i havent done it before but im pretty sure it needs it. I have dojne some pretty killer mud in my days and i havent cleaned the baby once.. IS there any product i will need besides carb cleaner? Also i have had some pretty bad problems starting her.. if i just turn it on and try to start it it makes a CLICKING NOISE.. is the started sticking somewhere or do i need a new one way? whats going on please someone help me i needa ride
Somone help me already i need to know.. I guess ill call a bike shop and ask them
Chompin at the bit, to go riding huh?
The clicking is the starter relay...try recharging the battery, and have it load tested, at Autozone or other parts store.Its probably just run down.
Unless you have symptoms, i wouldn't rush into cleaning the carb. Just because you go thru mud, doesnt mean the inside of the carb is dirty.
If the gas is more than 2 months old, and you didnt put Stabil in it....its probably no good. Drain it, and put new stuff in. Clean the air filter and reoil it. Check the spark plug.
If you want to clean the carb anyway...this article may help you.carb clean
