400ex air box tube
To keep the air tube from coming off the carb. do the following. Run one heavy zip tie on each side of the box (zip it to the frame). The box is held in place by a bolt in the rear, a white snorkle, and the black tube between the box and the carb. On the sides of the box are rubber grummets. This is where you need to put the zip ties. Mine has not come off anymore. Even during mx races.
*******DIRT GOOD PAVEMENT BAD*******
