primary clutch question
Old Feb 18, 2004 | 05:21 PM
589650's Avatar
Default primary clutch question
Just in the middle of installing a 700 primary spring and belt on my 650, found while cleaning up the primary clutch that the part that slieds in and out(not sure of proper name) has a bit of side to side play on the centre shaft of the clutch. it can be wiggled somewhat by hand, less so with the faceplate on, but still some movement. I'm wondering, is this normal or do I have worn bushings? Is this a common problem for the 02 650's that can be remedied by upgrading to a 700 clutch? Any insight is appreciated. Thanks.
Old Feb 18, 2004 | 05:43 PM
newbeatle's Avatar
there should be very little side to side play... you may be in the market for a 700 primary...
Old Feb 18, 2004 | 08:16 PM
SHOTGUN's Avatar
Mike;
where did you buy your 700 clutch....kawie
Old Feb 18, 2004 | 09:15 PM
589650's Avatar
Mike, I think I may be needing a new primary, also maybe a new secondary. The bushings in the secondary seem to be falling apart, can scrape grooves in them with my fingernail. I remember reading that you had replaced yours with a set of 700 clutches, was it both you replaced? Did you look into warranty? It seems like this could definitely be a man. defect, given that the new clutches have been changed. Have you noticed a difference with the new clutches, ie responsiveness, durability, etc? Thanks again for the help.
Old Feb 19, 2004 | 12:01 AM
Uinthas's Avatar
Getting tired of replacing parts on my primary clutch.. I have replaced a plate bearing, weights & pins & now I need new shoes.. I have 4k on my bike, is this normal for all belt driven clutches or is it just a poor kawi design??
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
