Hauling a P650
Old Feb 19, 2004 | 12:42 PM
sledheadrich's Avatar
Default Hauling a P650
Has anyone tried or seen a P650 stuffed in the back of an Avalanche? I'm thinking of getting some ramps but I'm not sure the Prairie will fit. Would be much more convenient than messing with the snowmobile trailer.
Old Feb 19, 2004 | 01:09 PM
SHOTGUN's Avatar
Won't fit;
Torn the plastic away from the foot rest just last Friday. It won't clear the lock down channel on the top, by about an inch....
Check out the bottom of my avalanche on my pic page.
Put it on top of the pannels.
later
Old Feb 19, 2004 | 05:30 PM
bandit33's Avatar
I'm not sure if the P650 is bigger than my V if it is it surely won't fit. There are two pieces of platic that I had to remove to get my V to fit in the avalanche... if the tires were any bigger or if the quad was more than 1/2 inch wider I don't think it would fit at all. Of course the tailgate will not close (that's a given). If your dimensions are the same or smaller than a V you should be fine.. If your tires are bigger you may have a problem too [img]i/expressions/face-icon-small-mad.gif[/img].... good luck
Old Feb 19, 2004 | 07:06 PM
700cc's Avatar
I had an Avalanche, and got rid of it for that very reason. You can fit the Prairie if you remove the plastic raingutters, and then remove the supporting brackets for the 3 panels. But then you lose the ability to cover the bed. After loading my quad against the midgate a number of times, the midgate/window area developed a terrible squeak and rattle. I finally traded it for a Sierra Z71.
badgerboy1
Sep 26, 2017 06:11 PM
shimanok2
Jan 29, 2016 07:37 PM
Sw00p
Sep 24, 2015 02:50 PM
Elkaholic
Sep 6, 2015 02:44 PM
