700 belt on a 360
Old Feb 20, 2004 | 12:54 PM
Uinthas's Avatar
Default 700 belt on a 360
Has anyone tired this.. Or is it best just to stick with the 360 belt?? Seen allot of post indicating the 700 belt is very good, & was wondering if it's better then the 360 belt & I assume it will fit, thanks..
Old Feb 20, 2004 | 01:02 PM
MikeyBoyesq's Avatar
Actually, I'm told that the P360 belt is a little longer than the P650/P700 belt...if that is true, I'm guessing that putting a P650 or P700 belt on a P360 will result in lower top-speeds b/c the belt will be unable to go all the way to the top of the primary pulley. Plus, I'm told that the P360 belt is just a hare wider than the P700 belt, so that the width of the P700 is not an advantage to your quad.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 20, 2004 | 04:13 PM
Uinthas's Avatar
Thanks for the information [img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 20, 2004 | 07:04 PM
newbeatle's Avatar
Actually I think the 360 & 700 belts are the same width ( where it counts )... but the 360 belt is a few mm longer... the shape of the 700 is improved, as the 360 belt is the same diamond shape as the older 650 belt...you may lose .5-1 mph switching to the 700 belt, just as the bigger twins may see a .5 - 1 mph increase... the 360 belt is already stronger than the old 650 belt... if you needed a belt, & there were no 360 belts, you may get by using a 700 belt, but it may be tight on the bases of your pulleys, & squeal in gear or want to walk at idle...
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
