details on the FST kits (650p)
i seen alot of $ signs floating around on the FST KITS so i thought i would ask the man himself! i asked if i could display his respond on this forum and MICKEY DUNLAP said ok.
the kit itself with cams, valve springs, pistons, sleeves, head gaskets and cylinder O-rings runs $1,040 with exchange on the cams. if he re-sleeve the cylinders here and re-o-ring the bottom of the cylinders it runs $340 for the pair. if you want port & flow work done to make both heads flow the same, its $500 for the pair. as of right now, he is not taking on any new motors and hes not sure of what the additional cost would be- i (MICKEY) personally havent done enough of them yet to know what it will cost for top-end engine labor on the twin cylinders. his estimate would be $500 out of the frame.
Lou Domenech
Sep 11, 2015 06:35 PM
