1991 200 fourtrax
Old Feb 20, 2004 | 10:32 PM
Trailblazinrider's Avatar
Default 1991 200 fourtrax
does neone have one? My dad's is not doing to well right now. Its the chain thats giving us problems. Two or three years ago, my sister kinda hit the side of it with the tractor, and it bent the back axle and broke the bolts holding it on. We got it fixed and now there is a new chain, somehow we broke that too. Now it is way too lose, and we cant seem to tighten it. We did what the manuel sed to do, but that doesnt do it. We need help, so if neone has some info for us we would greatly appreicate it.
Nick.
ps thanks for you time, in advance!
Old Feb 20, 2004 | 10:50 PM
KNOWSALOT's Avatar
The Facility
Taking a link out of the chain should do it.......considering the chain isn't shot.
Old Feb 20, 2004 | 11:08 PM
Gimpster's Avatar
Or if the sprockets are worn out.
----- Gimpster -----
Old Feb 20, 2004 | 11:11 PM
ya, i'll try that, but what tools do i need and if i dont have them, will places like menards have them?
thanks for the help
Old Feb 20, 2004 | 11:22 PM
Gimpster's Avatar
A wrench set rangeing from 8 mm to 17 mm should be what you need. I suggest the same sizes in sockets also.
I believe the four larger axle pivot holding bolts take a 17 mm wrench and the adjuster nuts utilize a 10 mm wrench.
Old Feb 20, 2004 | 11:26 PM
See, we tired that, loosen the four bolts then tighten or loosen the two on the bottom. That didnt work, i think we need to remove a link like you guys sed, but have no clue how to or what is needed to do that. But i will still give it a few more tires before removing a link. By the way which way do you turn the bottom two bolts that actully tighten or loosen the chain? Thanks much
Old Feb 20, 2004 | 11:31 PM
Gimpster's Avatar
Tighten should be out, counter clockwise on the inner nut, on the inside side of the tab. counter clockwise on tha outer lock nut also, to tighten. Note : there should be a nut on both sides of the holding tab, not both nuts on the outside
Old Feb 20, 2004 | 11:41 PM
there could be my main problem, there is only one nut on each of the bolts!!!!!! Thanks soooooo much, i'll run over to menards and pick some up this weekend. thanks again[img]i/expressions/face-icon-small-happy.gif[/img]!!!!
Old Feb 25, 2004 | 10:45 PM
ok, we found that the bolts are as tight as they can be, so we have to take a link out. On the last try we did something stupid. We hit the towing toung with a sledge, and it broke off. It is still ridable, but cant tow nething. Man, i feel stupid sometimes, lol!
Pehter
Oct 3, 2024 11:00 PM
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
