Mounting the IMS 4.6 gallon tank
Old Feb 20, 2004 | 11:48 PM
markdf's Avatar
Default Mounting the IMS 4.6 gallon tank
Hi,
I'm ready to install the IMS 4.6 gallon tank in my V-Force. It came with two 6" foam strips and the instructions don't mention where they go. I was guessing underneath the tank where it kind of sits on the frame rails.
Any help would be appreciated.
Thanks,
Mark
Old Feb 21, 2004 | 12:05 AM
Mudfoot's Avatar
That's where I put mine, no problems after 6 months. The tank is $$$ well spent. IMO
Old Feb 21, 2004 | 12:26 AM
markdf's Avatar
Mudfoot,
Thanks for the reply. I think that's where I'll put them.
Mark
Old Feb 21, 2004 | 12:51 AM
Mark82ndABN's Avatar
Ditto......that's where I put mine.
Old Feb 22, 2004 | 06:42 PM
markdf's Avatar
Thanks for the help.
I finished last night. The only problem, if you want to call it that, was lining up the mounting tabs and bushings to the frame welded nuts. I removed the IMS metal guides and reused the stock metal guides and put them inside the IMS rubber bushings. The stock guides are a one-piece metal item with a flat washer and metal tube as one piece (kind of looks like a little tophat). I pried them out of the stock rubber bushings (came out easy) and pulled out the IMS guides with a pair of needle nose pliers (came out easy). I figured the metal washer part would provide more area for the bolt head to exert force on.
I also removed the coolant lines from the carb. I went and bought 1/4 plastic connector along with a couple of vacuum caps for the carb fittings. I zip-tied the connected coolant lines so they wouldn't touch the front exhaust header.
Mark
Old Feb 22, 2004 | 06:59 PM
I did the same thing you did Mark, but not only did I reuse the stock guides but I also reused the stock rubber grommets as well....they snapped right in. The stock grommets are thicker towards the bottom and are formed much better than the ones IMS provide.
Old Feb 22, 2004 | 07:06 PM
Kawi650's Avatar
Can I put on on my thirsty 700 Prairie?
Old Feb 22, 2004 | 07:47 PM
rotty's Avatar
I had to reuse my grommets and bushings because mine didn't come with them. And I even drove right to IMS to pick it up. oh well
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
