Need Big Red help!!
Old Feb 21, 2004 | 03:21 PM
JP2's Avatar
JP2
Default Need Big Red help!!
Hi guys. I'm an amateur when it comes to ATV's so I don't know what goes with what. My problem is that I bought a 1984 Big Red 200 a couple of years ago. It runs great but the plastic is shot. I've tried Maier and all the other reproduction companys that I found on the web but haven't been able to locate any replacement rear fenders. Apparently no one makes them anymore. Does anyone know if fenders from another model will bolt on to my bike? Failing that, what are my options as far as modifying a set for another model to fit mine? Thanks for any help. John
Old Feb 21, 2004 | 07:57 PM
KNOWSALOT's Avatar
The Facility
The other models that share your rear fenders are........
82-83 ATC200E [slightly shaped different but bolt right up]
84 ATC200Es [ofcourse]
84-85 ATC200M
The fenders on the early ATC200 [nonS] models are close to fitting, but will require something different done to the rear middle section where your toolbox is. The early models had a different shaped toolbox and it will not bolt to your frame.
