hard starting
Old Feb 21, 2004 | 04:51 PM
Jeeptaz's Avatar
Default hard starting
i have a 85 kawasaki bayou 185. it is very hard to pull start it when i first try to start it, after its been running it starts up fast but the fist of the day is hard. i rebuilt the carb. could my choke be bad? if i open the throtle and spray in startinf fuild it starts . seems like the is not enought gas to fire it up after not running for awhile.
thanks for helping
jeeptaz
Old Feb 22, 2004 | 01:57 AM
hondabuster's Avatar
Actually it sounds like you got a handle on the situation. Not many 19 year old quads still around and running.
Try doing the regular maintance, such as new plug,clean and oil air filter, adjust idle speed and mixture screws. Does it seem to spin over slower when cold? You could try synthetic oil, it wouldnt drag as bad when cold.
Old Feb 22, 2004 | 04:28 AM
MuddyArkie's Avatar
Try turning the gas petcock off if it's going to be sitting for a while. Leaving it on can actually flood the carb while it is sitting for an extended period.
Old Feb 22, 2004 | 10:47 AM
Jeeptaz's Avatar
i don't have a stopcock it has a fuel pump, it has a new spark plug and oil. if i spray starting fuid in the back of the carb with the throttle up and then start it it runs
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
