Best pipe-Muzzy?
Old Feb 22, 2004 | 01:50 PM
Pistonman's Avatar
Default Best pipe-Muzzy?
Wondering if anyone has tried a Muzzy pipe yet and do they provide any jetting assist?
Old Feb 23, 2004 | 08:47 PM
Spaz40's Avatar
Yes, I have the MUZZY pipe on my 700. My opinion is that it is the best pipe hands down. The front and rear pipes are basically the same length which helps balance the HP between the cylinders. It fits great, looks great, and sounds better than any pipe I have ever heard. It is not as loud as duels but loud enough. It is by far the deapest sounding pipe for the V you can get, I guess becouse the canister is so long. Use MUZZY pipe, EPI pink spring, air box mods which I can give you if you would like, and 155 front-160 rear jets, twist throttle (my preferance) and you will have the perfect woods trail machine. The differance from stock to now is unreal, low, midrange, and top end, no sputters, flat spots, just pure instant power at any spead, on a hill etc. The answer to your question is no this was not my first set up on this bike but after a lot of trials and hard work it was the best. Hope this helps.
Old Feb 23, 2004 | 08:58 PM
TonyRoss700's Avatar
SOUND CLIPS !!! we want muzzy soundclips !!!
Old Feb 23, 2004 | 09:29 PM
Spaz40's Avatar
I am not a high tech guru. Tell me what is the best way to get a sound clip on here and I will do what I can.
Old Feb 23, 2004 | 09:46 PM
Spaz40's Avatar
They say the rear cylinder neds more fuel becouse it runs hotter but I think 160 front & back would be just as good. I am on the upper side of the fuel range right now but man is it crisp!!!!
Old Feb 23, 2004 | 09:47 PM
HappywithVForce's Avatar
Originally posted by: 3TV
With equal length headpipes shouldn't the carb jetting be the same front and rear?
Thats what I have been hearing, too. Spaz, Have you checked your plugs yet?
Old Feb 23, 2004 | 09:50 PM
Spaz40's Avatar
Not lately but it runs rich till it gets to opperating temp.
Old Feb 23, 2004 | 11:59 PM
markdf's Avatar
I think the rear cylinder should still be jetted slightly richer because it will run hotter. Even though these are liquid cooled motors, air flow still helps cool them.
Mark
Old Feb 24, 2004 | 12:11 AM
Pistonman's Avatar
I ordered the Muzzy pipe today with the jets that were said to match pipe. -forgot to ask size(at work) also ordered Q- core. Was told by Dave (at Muzzy) I would have a 10 HP gain. Have K& N , need airbox mods and clutching. Sat. I ordered Trail-Tech clamp,X-bars, twist throttle,Renthal grips. I will let y'all know what jet size they supply. What are TPI sliders? Any airbox mod help will be apprec. Thanks spaz ...EPI Pink-0/161...might try Dalton blue also-3/155 --or try some shims.......
Old Feb 24, 2004 | 12:17 AM
markdf's Avatar
Pistonman,
TPI sliders are Thunder Products Inc (TPI) sliding vent for the air box. There web site is
here
I can't wait to hear the report on the Muzzy exhaust. 10HP gain is pretty significant.
Mark
