Foot operated brake light
Old Feb 23, 2004 | 08:53 AM
Buzzman's Avatar
Default Foot operated brake light
After being quoted a $150 price for a brake light kit from Honda, I decided to do it myself. I installed a brake light on my Foreman ES. It just operates from the foot brake, but that's the one I use the most anyway. If anyone is interested, I can give you the part numbers and a description of what I did. It looks good and works great. Total cost of $30-$35.
Old Feb 23, 2004 | 01:42 PM
Coyotechaser's Avatar
I might be interested. It might be good to have a brake light.
I'm usually more concerned with if the person in front of me has a brake light. I've bumped my cousin a couple times during quick stops.
Old Feb 23, 2004 | 05:36 PM
gergb's Avatar
Buzzman, if you want the hand levers to operate the brake light too, just order these switches from your local Honda dealer. (I know they fit the 1997 - 2002 models so they should fit yours, see my pics. to compare them)
These are Honda Part numbers -
The switch p/n is 35340-ML4-005.(needed 2 of them @ $11.17 each)
Also needed was...
1 stop switch collar p/n 35345-HF1-830 ($3.78)
1 screw-washer (4x20) p/n 93893-04020-07 ($.55)
1 screw-wasger (4x14) p/n 93893-04014-07 ($.50)
Just screw them on and wire them in! Here is a link to pictures of my switch install. (you will have to register, (free), to see the pictures) The switches are waterpoof and are the same ones you get with the Honda brake light kit!
Old Feb 24, 2004 | 01:28 AM
RoughRider01's Avatar
Do they not have a brake light on the Honda Foremans or what? J/W cuz thats alittle odd.
Old Feb 24, 2004 | 01:31 AM
Gimpster's Avatar
The Rincon does, not any of the other models do....
-----Gimpster-----
Old Feb 24, 2004 | 09:24 AM
Buzzman's Avatar
Thanks, gergb. I'll probably go ahead and do that.
Coyotechaser, I went to my local auto parts store and bought the light, 3 wire plug, grommet and bracket. I then ordered a universal brake light switch from Dennis Kirk. I made an L shaped bracked and put it on the upper rear bolt that holds the plastic cover on the right side of the engine. I put the brake light switch through this bracket, and hooked the spring (comes on the switch) under the foot brake lever. Then I did the wiring. I mounted the bracket for the light on the bottom bar of the rear rack. I mounted it on the top of the bottom bar to provide clearance for the tool box door to open. Here are the part numbers. (The light parts are all PM brand.)
Sealed stop, turn, & tail light. #V421R
3 wire plug #431-491
Bracket (Lost this number)
Grommet#421-18
Swith(Dennis Kirk) #21-0119
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
DeFox500
Jul 26, 2015 06:32 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
